Hello,
Trying to upgrade my copy of david xl to david fx 2011 but the installation fails with an sql error. it simple states that it's failed to install correctly and the tobit installation will stop.
error is:
The installation of Microsoft SQL failed.
Please check the Windows Event Viewer. More information
can be found here. The installation is complete.
In the Windows log I could not see any error messages.
I've had google translator run through the forum and found a thread with exactly the same problem. How ever it's not that clear how it was solved, it looks like it was solved using a manual installation/setup of the sql but then other problems appear ? so i'm not 100% happy with trying the google translation of the fix :wacko:
This is the thread with the problem and fix?
David FX 2011 installation fehlgeschlagen (wieder SQL Server) :-/
Thanks for any help ![]()
