Kunde hat nur MS SQL Express und diese Meldung besagt Datenbank voll oder?
Der einzige Lösung besteht darin auf MS SQL Standard zu wechseln oder?
| SQL Error 80040e14 | |
| Code | 80040e14 |
| Code meaning | IDispatch error #3092 |
| Source | Microsoft OLE DB Provider for SQL Server |
| Description | Could not allocate space for object 'sys.fulltext_index_docidstatus_21575115'.'i1' in database 'David Archive Database' because the 'PRIMARY' filegroup is full. Create disk space by deleting unneeded files, dropping objects in the filegroup, adding additional files to the filegroup, or setting autogrowth on for existing files in the filegroup. |
| Function | m_Connection->Execute |
| Command | DELETE FROM msg WHERE arcID=176 AND [srFileName] IN ('i[00000000000004c00','i[0000000000000603b','i[000000000000064ac','i[00000000000009384','i[00000000000009b3b','i[0000000000000a4cf','i[0000000000000ad3f','i[0000000000000b0e7','i[0000000000000b580','i[0000000000000bd48','i[0000000000000ccef','i[0000000000000d543','i[0000000000000f74b','i[00000000000011a87','i[0000000000001504c','i[00000000000015 |
| User ID | ffffffff |
